No, the steering wheel for the AMG car will not fit the ealry 190E/d models. The stock Nippendenso compressor that is in your car should work just fine for 134Aunless you live in the desert.
No, your really don't. Your stock compressor will work fine with r134a, and it will blow ice cold. Installing a too-large compressor is not a good idea. A too-large compressor can cause the core to ice up, which will actually give you less cooling.Also, does anyone what I need to do to put a 10P17C Nippondenso AC compressor in place of the less powerful 10P15C compressor? I need more AC power for an R134a conversion.
