2001 ML320, 2000 ML430, 2020 Vito-Metris Cargo Van
Recently on my 2001 ML320, my ABS has been activating intermittently at low speeds as I approach a stop. Sometimes this happens and then the BAS/ESP-ETS-ABS lights come on. Usually, once I turn the vehicle off and then restart, the lights go dark and it operates as normal. Happens whether the brakes are hot or not. Yesterday, however, this happened and in addition to the trio of lights my Brake indicator on the instrument cluster came on and the beeping sound usually heard at startup began and did not end until I put the vehicle in park. Any ideas about what could be malfunctioning here? No ODBII trouble codes are presenting.
