1987 560SL & 1987 300TD
Hi All -
I'm restoring my '87 300 TD. The ABS light is on and I'm wondering how difficult this would be to diagnose. I'm wondering if this could be as easy as simply removing and replacing the ABS module?
Mike
89 300E; 00 E320
Maybe even easier if it is the OVP Overvoltage Protection Relay. You may want to replace yours with a new one.
This is the wiring diagram for the ABS - hope you do not need it:
Anti-Lock Brake System (ABS) 150 150-1
1991 300D 116,000m
If your OVP relay is original (One 10amp fuse instead of the redesigned two fuse), I'd replace that first. Behind the battery. Search OVP and ABS on the forums
