1992 190e2.3,2000 c230K,1999 E320
My 1992 190E 2.3 had to be towed last week because it would not start.Found the vacuum line under the intake manifold that goes to the idle-air valve off. The car now starts and runs fine but the ABS light pulsates and the transmission shifts hard.The transmission was rebuilt 1000 miles ago. I replaced the OVP relay fuse-no help. When you turn on a AM radio station you can here the pulsating-sounds like a turn signal blinker. The car was towed on a flat bed.
Any ideas?
thanks-Bob
Discussion Starter · #2 ·
Update:Found vacuum line off modulator valve. Found ABS relay on ABS servo(front left engine compartment) cycling. This was causing the light to go bright/dim and the static on the radio. Removed relay to de-activate system for further trouble shooting. Replaced fuse and then swapped OVP-no help.Any further ideas most welcome.
bob
The OVP was replaced last year with a new one. I replaced the fuse. I ran the car with the OVP fuse removed and there as a big difference in the idle, so I assumed the OVP was working.
