Hi guys
Today i changed the front rotors and brake pads on my 2001 C240 and i got all 3 lights on ABS-ESP-SRS could you please somebody tell me what is going on and how to remove them.Please and thanks
2002 C230 Sport Coup and 2006 ML350
I would get a full flush from someone who has DAS to pulse the ABS pump.
You must have done something wrong...
describe exactly what you did, step by step.
'01-E320 & 02-ST2
Hi guys
When is the last time you flushed the brake fluid? Did you crack the bleeder valve or just push the old fluid back up into the ABS system? Did you try the reset (described in manual)?
As other post says you need to explain everything, like 1000 percent more detail.
FWIW you don't need das to bleed the brakes which will fush it but take much longer.
Take care and enjoy the ride,
Greg
2005 C230K Sport Coupe 6-speed! And now a 2011 GLK 350 4Matic in Palladium Silver!
Sounds like you may have a damaged wheel speed sensor.
