I have a 2010 ML350 (gas) with 100k miles.
The ABS and ESP Warning Light have both come on. I scanned the ML with my new Autel DiagLink scanner and it reported the following fault codes:
ESP-Electronic stability program, Fault | 6
5101 L6/1 (left front speed sensor) : Carry out visual inspection. CURRENT
5102 L6/1 (left front speed sensor) : Check wheel bearing(s). CURRENT
5103 L6/1 (left front speed sensor) : Carry out visual inspection. CURRENT
5104 L6/1 (left front speed sensor) : Clean multipole ring and replace if necessary.CURRENT
5105 L6/1 (left front speed sensor) : Implausible wheelspeed CURRENT
5106 This fault can be ignored and erased. CURRENT
Event 6001 the supply voltage of the control unit is too low (undervoltage).
Where is the "left front speed sensor"? What should I look for when doing a "visual inspection"? Do these codes look valid? Any thoughts on what to do next? To repair? Next steps?
Thanks in advance for any advice and assistance!
Sent from my iPhone using Tapatalk as best I could.
-Brian
Lima-Lima-Mike-Foxtrot
-Brian
