2002 CL500 AMG Sport Pkg
about 12 months ago I had my ABC pump and lines replaced (warrenty ran out and was very costly) and now the grinding sound that I had before the last pump died is back! and also when I park the car for even an hour my front passenger wheel is dropped to the ground. If I raise the car and then drop to normal it levels out. My question is this.. Iknow the dealership is trying to get out of replacing my pump again so I would like some ammunition for my argument when I go back to the dealership. Has anyone else had this problem where they say it's normal? I had the car for 5 years and I know the pump doesnt make that sound and I would remember if the car drops that much after an hour. It's BS! I can tell the performance is greatly affected as well, I used to be able to do 50 mph on the on cornering on ramp with no problems now if I try that speed It feels unsafe like the car is having a hard time cornering.
Alex
560 SEC Supercharged(sold), E55 AMG, Renntech CL600 Bi-turbo, Porsche 928
No, it's not normal. None of it should be occuring. I've had mine replaced 3 times in the last 6 months. I had to pay for the first one and the dealership replaced the other two.
It's a good possibility they did not flush the system properly. That will grenade a pump sooner than later.
2002 honda civic (sold), 2009 Mercedes ML350
the issue with the front dropping is due to dirt clogging the valve block or a faulty valve block. there are DTB's out on it specifically saying to start with a flush and if it continues, replace either front or rear valve block.
