Dave - Good to hear that there is someone who is at least familiar with the system! That is what I would like to be in future, as well
Regarding the ABC control unit: I have changed pretty much all, but that one is only overhauled. I also noticed from my notes that when that control unit came, I got solid 173 Bar pressure during the whole 15 min pressure sensor test. So it is just a wild guess that it may - or may not - have issue.....
How does it behave, if the heights are not perfectly the same? How accurate those need to be adjusted and what will happen, if those are not? With that note about heights, you referred to the replacement of control module?
Have you ever tested how much is the flow from pressure relief valve back to the ABC hydraulic oil reservoir? Does that amount of oil flow give any indication about whatever?
How can I be sure what is the correct unit, if the previous owner already changed a wrong on there? My model is 2001 CL 600 before August that year - I assume. Anyone knows what codes are used that time?
@mersumies - yes, still struggling with the same Mercedes. Only issue is the hydraulic pressure. At idle - 750 rpm - the pressure goes down when warming up; but if i give it to 900 rpm, it goes to the ceiling - which seems to be limiter - 172 bar and stays there. I even think that could it be that that absolute figure is erratic, and the correct, real pressure is something else - like 193 bar. And that is because all the pumps + 3 units, which I have tested behave the same way! Pressure sensor I have changed twice. I have used two different pressure relief blocks, as well. All the pumps have had its new suction valve. Pipeline from the pump to the pressure relief/pressure sensor is new, as well as damper. All the solenoids have new O-rings - and the car stands on on its wheel forever; no sagging, no leaks.
And the motor runs perfectly. I changed the oil-water cooler also, ingnition coil, sensors lambdas etc. And oil seals here and there, also the left cylinder bank valve adjusting hydraulic systems - that one by the way had stonehard, leaking O-rings!
