Great post Peter - will add this to the stickies when i get it up
get the fluid from Phoenix lubricants in oz - it is $26 a litre for Pentosin CHF11s
I just did mine and I only jacked up the left side and removed the lower cover on that side for access. The accumlator is mounted to the valve block assembly chassis with three nuts and one hydraulic fitting. The hardest part for me was getting the accumlator out with out bending or disturbing any other fittings and tubing. It does come out though. You must wiggle in the new accumulator. Be patient and persistant and it will go back in.Beautiful write up. I am about to tackle my front one on my R230. I need to know if I jack up the front 2 wheels only will that let the pressure off after 30 minutes? Does the front accumulator just sort of lay there as in the photo? I thought it was interconnected to the valve block? It looks easy to pull it out if it just lays in there that way.
Moretech
USA
You should have minimal fluid loss during the change over. I lost perhaps an ounce if that. I just put rags up to catch the drops. Let the car sit idle for least 30 minutes before change over and you should be fine.I will have my accumulator in the car tomorrow afternoon. Got panels down, looks very straight forward. Just one question. Just how do you bring system fluid level back to normal? I can catch all the drained fluid for a volume check but do I then start a partial flush? I need to see into the reservoir to make sure no air gets in the pump and to do this I need to pull the filter, fill it up good, and start a flush . Maybe 3 liters might get the air bubbles out.
Moretech
So responding to my own post, here is what I did to replace the front accumulator on my 2008 SL550. Note the usual disclaimer about this just being a report of what I did and not a recommendation.+1 on the great post.
I want to replace my front accumulator this weekend; will do the rear soon. My car is a 2008 and the WIS says to take out the front valve block. Is that really necessary? The accumulator is somewhat tucked behind the block compared to some photos I've seen.
