For you doing the pods in the future, their availability is falling fast. Below is how I got creative with what pods were still available new and which ones weren't available and I had to either buy a different new one that wasn't the right one for that specific purpose, but by doing so cannibalize its parts into my current one or to use a diaphragm rebuild kit.
Since I didn't want to buy and install the Performance Analysis rubber diaphragms inside my existing pods unless I absolutely had to, I tried to see how I could buy as many new factory pods as I could and found out that you have to get creative. That being, not always using the Mercedes brand of number in your search, but sometimes the Behr and/or Hella brand in your search words. You can also buy a known available pod and sometimes cannibalize its innards into other pods, and vice versa. Since I have bought some, I'm not sure if the places I did find them has any more; I'm just indicating where I did get them from during the last two weeks.
From left to right, let's call it pod #1 through #6:
#1 Diverter pod by gas pedal (single nozzle and diaphragm). Green vacuum line goes to it, and other end goes to spot #6 on the Y7 tree
PN:
Mercedes: 0008004075
Hella/Behr: unknown
Alternatives: 1) Use Performance Analysis diaphragms, OR 2) If you can buy a 0008006775, remove its diaphragm, and remove its arm by drilling out rivet. Remove rivet and arm from the old 0008004075, and re-rivet it onto the 0008006775's diaphragm and put it back into the 0008004075 housing. Reason being, the 0008006775's housing has the three "pegs" that push into the dash, and the 0008004075 has three "tabs". OR 3) If you can buy a 0008004375, 0008005775, or 0008005875 you can remove their respective lower diaphragms and put it into the 0008004075, and unsnap their arms and rivet the 0008004075's arm to it or use a small screw and nut or cotter.
#2 Footwell pod behind radio (black square). Red with yellow/orange stripe vacuum line goes to it, and other end goes to spot #3 on the Y7 tree
PN:
Mercedes: 1268001475
Hella/Behr: 351329391
Alternatives: 1) None, since square, use only new pods. I bought from mbpartscenter.com using the 1268001475 Mercedes part number
#3 Hot air flap pod, behind radio (single nozzle and diaphragm). Red with black strip vaccum line goes to it, and the other end goes to spot #4 on the Y7 tree
PN:
Mercedes: 0008006775
Hella/Behr: 351329181
Alternatives: 1) Use Performance Analysis diaphragms, OR 2) I bought from euroimportparts.com using the Hella/Behr 351329181 part number OR 3) If you could buy a 0008004075, you can drill out the rivet, remove the arm, and re-rivet the 0008006775's arm to it and reinstall both diaphragm and arm attached back into the 0008006775 OR 4) If you can buy a 0008004375, 0008005775, or 0008005875 you can remove their respective lower diaphragms and put it into the 0008006775, and unsnap their arms and rivet the 0008006775's arm to it or use a small screw and nut or cotter. OR 5) Maybe use parts from W124 pods, but I have yet to compile this as I haven't dug into my W124 dash yet. I'm figuring you can as the Performance Analysis diaphragms (the 2010's) are called out for both W124 and W126.
#4 Defroster pod, up to the right of console (double nozzle and diaphragms). Red with white stripe vacuum line goes to the top or outermost nozzle . The other end goes to spot #5 on the Y7 tree. Red with blue strip vacuum line goes to the bottom or nozzle closest to the arm. The other end goes to spot #7 on the Y7 tree
PN:
Mercedes: 0008004375
Hella/Behr: 351329241
Alternatives: 1) Use Performance Analysis diaphragms, OR 2) I bought from mercedespartscenter.com using Mercedes part number OR, also on Ebay and Autohaus OR 3) If you could buy a 0008005775 or 0008005875 you can transfer the arm (which just snaps on) to the 0008004375. However, you need to note the orientation of both sets of pink housings relative to the black housing. Make them match how the 0008004375 is or the nozzles will face the wrong direction upon snapping the housing all back together OR 4) If you can buy a 0008006775 you can remove its lower diaphragm and put it into the 0008004375, and unrivet its arm and rivet the 0008006775's arm to it or use a small screw and nut or cotter. This doesn't address the top diaphragm however. OR 5) Maybe use parts from W124 pods, but I have yet to compile this as I haven't dug into my W124 dash yet. I'm figuring you can as the Performance Analysis diaphragms (the 2010's) are called out for both W124 and W126.
#5 Main flap left pod, behind glove box, second from the right from outside of car (double nozzle and diaphragms) Green with blue stripe vacuum line goes to the top or the outermost nozzle by way of a rubber "Y" fitting. The other half of the "Y" fitting continues on to Pod #6 (see #6 below). The other end goes to spot #2 on the Y7 tree (shares with pod #6). Dark red vacuum line goes to the bottom or nozzle closest to the arm by way of a rubber "Y" fitting. The other half of the "Y" fitting continues on to Pod #6 (see #6 below). The other end goes to spot #1 on the Y7 tree (shares with pod #6).
PN:
Mercedes: 0008005875
Hella/Behr: unknown
Alternatives: 1) Use Performance Analysis diaphragms, OR 2) I bought one on Amazon, and I think Europarts.com may have it also, OR 3) If you can buy a 0008005775 or 0008004375, you can put the 0008005875's arm onto either of them. However, you need to note the orientation of both sets of pink housings relative to the black housing. Make them match how the 0008005875 is or the nozzles will face the wrong direction upon snapping the housing all back together OR 4) If you can buy a 0008006775 you can remove its lower diaphragm and put it into the 0008005875, and unrivet its arm and rivet the 0008005875's arm to it or use a small screw and nut or cotter. This doesn't address the top diaphragm however. OR 5) Maybe use parts from W124 pods, but I have yet to compile this as I haven't dug into my W124 dash yet. I'm figuring you can as the Performance Analysis diaphragms (the 2010's) are called out for both W124 and W126.
#6 Main flap right pod, behind glove box, farthest right pod in the car (double nozzle and diaphragms). Green with blue stripe vacuum line goes to the top or the outermost nozzle by way of a rubber "Y" fitting. The other half of the "Y" continues on to Pod #5 (see #5 above). The other end goes to spot #2 on the Y7 tree (shares with pod #5). Dark red vacuum line goes to the bottom or nozzle closest to the arm by way of a rubber "Y" fitting. The other half of the "Y" fitting continues on to Pod #5 (see #5 above). The other end goes to spot #1 on the Y7 tree (shares with pod #5).
PN:
Mercedes: 0008005775
Hella/Behr: 351329271 for Hella and W01331619776BEH for Behr
Alternatives: 1) Use Performance Analysis diaphragms, OR 2) I bought one from mbpartscenter.com and I think Ebay had them too under the Behr W01331619776BEH OR 3) If you can buy a 0008005875 or 0008004375, you can put the 0008005775's arm onto either of them. However, you need to note the orientation of both sets of pink housings relative to the black housing. Make them match how the 0008005775 is or the nozzles will face the wrong direction upon snapping the housing all back together OR 4) If you can buy a 0008006775 you can remove its lower diaphragm and put it into the 0008005775, and unrivet its arm and rivet the 0008005775's arm to it or use a small screw and nut or cotter. This doesn't address the top diaphragm however. OR 5) Maybe use parts from W124 pods, but I have yet to compile this as I haven't dug into my W124 dash yet. I'm figuring you can as the Performance Analysis diaphragms (the 2010's) are called out for both W124 and W126.
Hopefully between using new diaphragms, or tweaking the 2 or 3 other pods still available to buy, or the same concept but using W124 pods, you can piece them together to make something work.
