No warning lights. Starts fine and idle's fine. If you press the accelerator down a fraction it will rev as normal. But if you press it down quickly to half it will misfire. I have already replaced the Fuel filter as that was my starting point for troubleshooting my little problem.
I've checked the MAF and both sensors arel intact and has no signs of burning or discoloration. The Throttle body was a bit dirty but I have cleaned it up and will reinstall the MAF and throttle body to see if it makes a difference.
How much pressure should the fuel pump produce?
Please your wisdom is needed oh oracle's of MB's
