1 - 10 of 10 Posts
1995 E320 Wagon, 2002 S430
Our 95 E320 wagon has begun to make a new noise. The noise is a very low pitched sound -- almost sounds like a subwoofer at 30hz. No grinding, just a smooth very low frequency tone. The sound only appears while on the freeway at 50+ miles per hour when LETTING OFF THE GAS. It is loudest when doing this at 70+ mph. The very second I engage acceleration, the sound completely disappears. Any ideas? Drive shaft? Rear diff? Trans?
· Banned
1993 400E
I have a few idea's, but you never reported back after this thread........ 3 months ago??
http://www.benzworld.org/forums/w124-e-ce-d-td-class/1738385-timing-marks-intake-cam-timing-hg.html
Sharp as a tack Clark. Had to hang up my wrenches in September shortly after getting underway on that project. My Lyme disease went into full flare and shut my digits down pretty bad (my grey matter too) to the point I could not hang onto a wrench or do anything requiring any level of dexterity. Am just now starting to come back online slowly but surely.
Thanks for your help.
Discussion Starter · #6 ·
I suggest checking the flexible joints for wear and noise.
I wish you all the best with your health.
Thank you.
I just replaced the flex disc (front) in May but should get back in there to make sure no nuts/bolts have come loose and made their way out onto the freeway (have read a few folks reports of this happening). Thanks for the suggestion.
· Banned
1993 400E
If anyone knows about health problems it's me, so I sympathize.
On the noise, check the diff oil, maybe drain and refill with fresh.
Have you ever serviced the diff, MB recommends every 30K on
the older cars. I wouldn't push it past 60K
300e 1991 34K
what might " service " entail Clarkz ..??
I can not believe a need for checking much, or setting anything, after all .. it's Merc :)
right ..?? :confused:
I am still using a Ford 9" that I JY'd in 1976, never anything but fluid changes
it's been driven by a 428SCJ, a 460, and now a Chevy 468
· Banned
1993 400E
Reread Clark's post, servicing the diff means R&R diff fluid.
Yes, that's right.
I drain the diff, removing the fill plug first, then the drain so you get nice flow.
Then I'll squeeze a little fresh lube in to flush out as much old oil as possible.
Reinstall drain plug and fill it up until it just starts to drool out.
I use Mobil 1 synthetic gear oil. Spec is 75W85, but the 75W90 is OK
1 - 10 of 10 Posts
