1988 560 sel
Ok so my 560 sel has alot of problems ...
1. cold or warm start wont start with just turning the key its goes clickclickclick...... then a little start but its at like 150rpm and i have to press the gas to start it right
2 Rough idle it idles at 500 rpm but the whole car moves there is no diffrence in idle if i put it in park or drive but if i rev it up to 1000rpm it smooths out
3 engine feels lumpy along with the economy gage is constantly in red or right in the middle with just slight accleration ie: away from a light
and it is using alot of gas i have noticed these past 2 days
ON a side note it passed smog today in arizona and well below the numbers listed for federal approval but guys please give me a list of what it could be
I was thinkin maybe the timing chain is too slack and it thru the timeing off but im not a mechanic im more of a guy that will poor money into the mechanics hands
1982 280 se aut. ecc. - sold
Looks like you have a loose vacuumline and because of that the engine runs very lean!
gr J
1988 560 sel
ok and just to get ourselves on the right track the vacum lines are all of those colored rubber or vinyl tubes running around the manifold
1988 560 sel
ok so how would i go about fixing this vacuum leak and also i seem to have a ps leak that leaves a nice puddle after i let it sit for a few hours
1990 SEC
You need to do a search on this forum for "high idle", "rough idle", "vacuum leaks", or any such combination. This sort of problem is fairly common with high-mileage, deferred maintenance vehicles.
The power steering leak is probably the high pressure line. It has also been discussed with some frequency.
