1 - 16 of 16 Posts
Mercedes "M32"
Hey guys, I was wondering if you all could help me answer a few questions about my friends '79 230GE.
1. Is the rear locker manually activated? (i.e- lock when I push a button or pull a lever?)
2. Can the locker be activated in 2WD or only 4LO and 4HI?
3. Can I get a locker for the front axle?
4. Do all of the 79's come with A/C standard?
Thxs in advance for all the help and info ...
Mercedes "M32"
Discussion Starter #2
Also what are the specs on the 230GE engine ... like HP and TQ. Thxs again !!
2000 G500 NMLE
RE: A few questions about a 79 230G ...
1.) Yes - Lever
2.) Any position of the TC.
3.) Buy a whole new axle.
4.) No. It was not even available as a factory option until 1981.
2000 G500 NMLE
MLOffRoad - 5/8/2005 3:52 AM
If it's a 1979, it's not a GE. It's a 230G - carbureted. If it is indeed a 230GE - fuel injected, it's not a 1979. Fuel injection on the 230 didn't show up until 1982.
The original 230G was 90 or 120 HP, depending on which engine (high or low compression) was ordered.
Arnd has a very good website for this information, but it appears to be down right now.
http://www.g4rce.net/engl/index.html
Mercedes "M32"
Thank you for all the information DUTCH ...
Also how would I find out if the vehicle is a high compression or low compression engine ?? Do I decode the VIN# ??
2000 G500 NMLE
MLOffRoad - 5/8/2005 1:02 PM
Yes, but I don't know which engine number is which.
Mercedes "M32"
DUTCH - 5/8/2005 1:07 PM
Roger that ... if anyone else knows please chime in.
2000 G500 NMLE
4x4rancher - 5/15/2005 5:59 PM
Is that the carburetor engine?
If it's a 1979, it will most certainly be. The fuel injected GE version wasn't available until 1982.
230 G BGS 300G TDI
So thats the engine we had in the early 230 Gs in Berlin great little engine even with the lower bhp and easy to fix.
I bought one recently then swapped it for the later GE model I have now.
2000 G500 NMLE
4x4rancher - 5/15/2005 6:30 PM
There were two different 230G engines prior to the 230GE. One of the two was low compression (and HP) and the other was high compression - 90 HP, I think.
1981 240 GD
a very thirsty engine....
The original engine in my G was the carburated-high compression engine qith 100+ HP...a very thirsty but reliable engine as I heard.
fernando
230G
RE: a very thirsty engine....
From my experience, mine is still a 230 carburetor, however the original engine has been replaced by a w123 230 sedan, so i don't know if it is a high or low compression, i think it s a 90 HP (it used to be[:D]) which is delivering not more than 60 hp now (it has 100K) , very thirsty engine, very slow, but extremely reliable and easy/cheap to fix.
1 - 16 of 16 Posts
