Folks,
I'm brand new here. I don't own (and can't get) an A-class in the US, but I happen to have a Porsche race car (2001 GT3 RS) I'm restoring that uses a VDO power steering pump that is apparently the same as those found in the A-Class cars. The one that came in my Porsche had been modified by the previous owner (over 10 years ago) to include an external solenoid. I'm not sure exactly why the solenoid was added, but it was reportedly due to problems that were experienced with the pump. From reading the forums, I can guess why this might have been, but I'm not sure. In any case, I wanted to replace the pump.
So I bought a remanufactured unit from BBA Reman in the US, which was sourced from their facility in the UK. It carries model number A 168 460 0601 and looks identical to the one in the Porsche. But there is one exception -- it has four wires, whereas the original pump only has three. Each pump has a red, brown, and blue wire, and I know the function of each and where they should be connected (assuming each pump operates similarly, that is). But the new pump has another, fairly small-gauge wire that is green with a purple stripe. I don't know what this wire is for or whether/where it should be connected.
Do any of you have any knowledge of this? It would be helpful to have an A-Class wiring diagram or a VDO pump wiring diagram to figure this out, but such information is scant over here. I'd appreciate any advice anyone could provide.
Thank you in advance.
Rob
Rob
