1997 M B E420 1990 Porsche 964 C2 Coupe
The A/C on my E is not working right. The air on the passenger side is fine, nice and cold. However, the drives side air dose not cool donw. What should i do?
'01-E320 & 02-ST2
Or just clean the duovalve, which sounds like the issue. If not then run the diagnostic.
FWIW you can find most answers in the help/diy stickies and through the clever use of the search function.
Take care and enjoy the ride,
Greg
It is either the duovalve letting hot water into the left heater core, or insufficient refrigerant flow through the evaporator. Insufficient flow is caused by low refrigerant level, a blockage, or a bad compressor (in order of probability).
