Hi every one,
My SL600 1993 Interior A/C Blower it doesn't work proberly, some time it's work very weak, suddenly cut off I dont know why
any one have Idea about this problem? :crybaby2: :bowdown:
Mohammed
Outstanding Contributor
2003 SL500, 2003 SL55, and four R129s
I would run diagnostics as currently being discussed in this thread: http://www.benzworld.org/forums/r129-sl-class/1314519-ac-control-issues.html. You should already own a copy of the Mercedes WIS software -- its only $10 from an eBay seller in the U.K. -- which will give more information on the diagnostics. If you need to troubleshoot further, the WIS has schematics that you can use to determine where your problem is.
