I used a scanner, no codes for the A/C.At the minimum, you need a vacuum pump, a gauge set and a MB scanner.. Prices start at about $250 for the cheapest ones out there.. Most important,.. you need the knowledge "how to service an AC system,.. Must be hundreds of videos on Youtube on this subject..
OR,. call around and find a independent shop that will do it for less than $500
Scanner does not have access to live data?I used a scanner, no codes for the A/C.
