On 1994 S500, A/C just stopped working. It worked OK (not very cold) untill a few days ago.
I tried to charge it with R134a, but nothing goes into the system.
I noticed the compressor is not running. Sometimes it will turn for a few seconds when I first push the A/C button, and then it stops. Usually will not turn on again untill I shut off the engine and wait for a couple of hours.
I checked the refrigerant Hi / Lo pressure and it is about 70psi on both sides.
It seems like the compressor is being shut off because the pressure is too low. If so, How can I charge it if the compressor is not running.
Is there some kind of an reset button, or a way to force the compressor ON temporarily, so the system can be charged?
Any help appreciated.
Thanks,
BJ
Thanks,
BJ
