1 - 20 of 31 Posts
1997 S500
I got a 1997 S500 and the A/C compressor is not turning on and in the A/C control the EC button stays turned on and
cannot be turned off which keeps the compressor turned off. In the diagnostics menu I can see an A/C pressure of 4 bar.
Why is the EC mode turned on and cannot be turned off, is this an issue with the compressor?
1997 S500
Discussion Starter · #12 ·
OBD2 Scanner does not show codes for A/C system. Procedure will be found if you search Benzworld for A/C Fault codes.
I must be doing the search incorrect, but I can only find a list of the fault codes and besides the OBD2 cannot
find any other mention to where I find specifically the AC codes and how to reset any codes.
1997 S500
Discussion Starter · #17 ·
Here:
They can also be tested using the 38 pin connector under the hood, using Mercedes STAR diagnostics. The OBD II connector only works for engine diagnostics. Everything else uses the 38 pin.
Jon
Here:
Jon
I just got a 38 pin to OBD2 adapter but I have not tried it. Maybe that will work
1997 S500
Discussion Starter · #20 ·
Here:
Jon
Here:
Jon
Try on Benzworld search W140 Forum "
Automatic Climate Control Diagnostic Trouble Code (DTC) Memory
That worked, thank you very much
1 - 20 of 31 Posts
