With summer approaching (which lasts about 6 weeks here in the Pacific Northwest), I decided to turn my attention to the A/C in the '94 E320 (v2.0, the one I bought last November).
The blower happily blasts away ambient air with the A/C cranked up full. So the first thing I did was open the Schrader valve and plug in a can of R134a, figuring it might need a recharge. Imagine my surprise when I found that the system pressure already registers 100 psi. Thinking the cheapo pressure gauge that came with the can wasn't reading right, I plugged in another can of refrigerant I had and got the exact same reading on its gauge.
I depressed the pin on the Schrader valve and got a loud rush of refrigerant. So it appears that the previous owner tried to remedy the A/C issue by cranking in 100 psi worth of R134a. Yay.
I figure my next step will be to bleed the system down to a more reasonable pressure, even though any damage to the system from overpressuring has probably already been done.
Once I have done that, I am wondering what my next step should be in trying to troubleshoot the system. Thanks.
do a search for reading ac codes and sensor values. i reported mine here and learned my evaporator temp. sensor had failed. $20 for a new sensor later (coulda replaced the resistor therein for $2) and my ac blew cold again!
I found this one:
W124 Diagnostic Trouble Codes (DTC) – Models with M104 Engine Only!
Pin #7 dumps the codes for the automatic climate control. What catches my eye are pulse readout #4 (Outside air temperature sensor, short-circuit) and #5 (Outside air temperature sensor, interrupt). On this car the outside air temperature on the dashboard goes in and out, and when it is showing a temperature it is clearly wrong.
So I'll see if I can scare up someone with a scan tool, or just go ahead and replace the outside temperature sensor.
Thanks for the tip.
Grab a strong flashlight and see if the clutch of the compressor is engaged and spinning at engine speed.
If the face of the compressor is not spinning, compressor is not engaged.
About this Discussion
4 Participants
sbaert
Mercedes-Benz Forum
Full Forum Listing
