So I havn't been having AC for a while now. In this heat I'm really getting irritated by it. So I charged the system with 30 lbs of R-134a and It lasted roughly about a month.
I thought there was a leak so I got the UV R-134 and charged via Low side port.
It was about 12 ounces.
It comes to find out I think I have a leak from the valve on the High Side port since I noticed small air bubbles and the Green(UV) ink was inside the cap.
Which it shouldn't be since I charged it on the low side.
When I took the valve off I let the remaining pressure out of the system via the Hgh side port. A good amount seemed to come out pressurized.
Does this mean that my system holds a charge but doesn't get cold ??
Ive looked around as well (with an actual Flourescent black light) and I cannot see any more leaks
I have looked at the DTCS for the AC as well. It's just the codes I have dont seem to match up to the ones in the car(unless Im reading it wrong) Is there one specifically for the 96 280 sports
Also I've read the cabin air temp sensor could be bad. The one I have used to buzz (Ive read this is a sign of it being bad) Now it doesn't anymore.
I'm going to replace the valve but would like to know more as this heat is killer.
Any help on this situation would be greatly appreciated since I drive back and forth to the dessert :surrender::surrender::surrender::crybaby2:
Thanks in advance
Thanks in advance
