MB 180 W120(1962) MB C200 W203(2007)
My W 203 C180 compressor blows hot air when a/c is switched on.
But it blows cold if temp is set at minimum (18^C).
Any setting at above 18^C, immediately blows hot air. No loss of freon.
Any suggestions welcome, Thanks.
It's likely a bad sensor in the overhead control panel. If you have a sunroof, try opening it and see if that makes a difference. If so, that's it. Here are the details on a cheap fix:
