When I put the A/C in my 1994 E320 W124, on high it blows a fuse, every time!
This is very annoying to say the least.
Help is very much appreciated.
93 300ce cabriolet, 03 Infiniti Q45, 03 Honda Accord
Ballast resistor behind the driver's side headlight.......possibly. Anybody else?
2003 G500, 2000 SL500, 1995 E320 Cabriolet, 1980 TR8
If you are blowing the big 30 amp fuseable link, then then I would suspect the blower motor as it is most likely drawing too much current at full tilt. If you are blowing Fuse 1, then I would suspect the CCU or the blower motor speed controller (e.g., resistor).
