41 - 58 of 58 Posts
2006 CL55 AMG, 2002 E320 (totaled), '72 Datsun Z
As a general rule, melted fuses and fusebox connections are a product of resistance in the connections, not high current. Current thru resistance causes heat.
Agreed. In this case I can confirm a high current situation due to a shorted fan motor and a fuse that didn't blow.
It was fun while it lasted
2002 ML320, 2005 S430 4MATIC RIP, 2010 F150 Crew Cab
Discussion Starter #42
In my case, the blower motor was fine. It was the regulator that eventually caused the meltdown.
What is really interesting about that in both failure modes; regulator failure and motor failure; the fuse did not open the circuit before melting. Yuck!
1998 E320 base sedan @ 160kmiles
In W210, there is no fuse. The fuse is the blower regulator switching transistor pair :)
This shows a 10A and a 15A fuse for "Blower Motor AC" in the primary fuse box in the engine compartment which makes me feel better for the wiring in my W210 vs my w215.
E Class (1996-2002) W210 Fuse Box Chart Location Designation Diagram ? MB Medic
They are not for the blower. They are for the a/c controller which "controls" the blower. The blower in full speed will consume about 30 to 35 amps. The blower is hardwired to the unfused + terminal block, and the other terr terminal is connected to the regulator which completes the circuit to the ground terminal behind the dashboard.
No melting fuse box with that setup! Don't want to nick the wire insulation though :eek
I had a Vanagon that had a dashboard smoke up badly when some insulation rubbed off a wire. That car fused the circuits just before ground, not close to the 12volt which is more customary... and safe.
That must be the reason why they deployed pre-fuses, instead of the terminal block like X4 which provides power to the blower as well as many other circuits. There may be a fusible link in the terminal, I am not sure. Else, the 4mm red wire that supplies power to the blower motor would be toast. Anyway we digress, this is the W220 forum :)
@wallyp for the win! I took apart the donor car's fuse box and lots of corrosion on the fuse blades as well as some heat scoring on the plastic. Also found a weird bit of plastic on the hot blade holder... The fuse in my car was probably mostly melted prior to the blower motor shorting out. The shorted blower just finished off melting the plastic and coating the fuse until the low voltage problem began.
The top row of fuses are the originals and the bottom row are the donor cars fuses. The blade the broke off was welded into the platic of the fuse box and got distroyed. Makes me want to replace every fuse in the car... Routing the power to blower outside the fuse box like @cmitch did is the way to go even before the problem occurs. At a minimum, everyone should replace the 40 amp MAXI fuses with new and di-electric greased parts.
W220 2003 Update S500L, W204 2008 C220 CDI
...At a minimum, everyone should replace the 40 amp MAXI fuses with new and di-electric greased parts.
ABSOLUTELY agree!
IMHO it is not the shorted blower or regulator that causes the problem with overheated fuse box and fuse link although it accelerates the problem and brings it to a failure.
The real issue here is corrosion on the fuse link contacts which introduces resistance into the circuit. Then even a small current through the circuit will generate power and hence heat as per Power = Current squared times Resistance. Notice double the current you get four times the power! So when you get a current increase due to a failure down stream the heat rockets up dramatically.
The solution as has been said by wallyp, GreenZZ et alia is to check the fuse links and as a minimum grease them to keep the air away. If there is any sign of corrosion replace them before the issue gets bigger.
Brian
2003 S500
Some great products to help the fuse corrosion problems:
Stabilant - Great (but pricey!) product from Canada, eh.
Corrosion Block.
DeoxIt 5.
Google is your friend...
Parts all came in and I put my car back together. Confirmed @mrboca current draw. Measured 24.3 amps both at the input to the regulator and the input into the blower. I measured at idle; forgot to rev the motor/alternator. I'm sure it goes to 30 at 1800 rpms. I'm still wired through the fuse box. I'll rewire it before summer. As recommended by @ricebubbles, I took apart the prefuse box on the floorboard and brushed it and greased it. Need to do the one in the trunk.
Very thankful for the guidance!
The inrush current is more than than steady state current. That is why you have a slow blow fuse.
W220 Moderator
Try reading the whole thread, but I'll make it easy for you ................
Post #33 on page 2
CL500 2000
Post #33 on page 2
Thank you Dave2302. Actually what I am looking for is a clear color picture of Blower Fuse Connector (X64/1) itself. Mine has been bypass so no Blower Fuse Connector anymore, so I would like to return it to original condition. I found the following picture of X64/1 but its black/white. Appreciate if someone have a clear color picture ones.
W220 Moderator
Hi,
I've never seen that in any 220 / 215 Fuse Box, I think you'll find that one has been bypassed already ????????????????????
Cheers Dave
2000 S430, 2003 S430, 2000 S500, 2003 S600 TT, and 2005 E320 CDI
Just did this with the S600 TT. Turns out to be a flaky blower motor, likely as a result of at least two cases of reed valve clogging and water entering the passenger compartment. That blower motor is coated with oxidation all over.
The second time was earlier this year (2018) during a major rain storm. The whole interior got taken apart, and I took a wire brush to every electrical contact that I could find. Yep, even the CANBUS connectors and where they plug into. Took the rear SAM completely apart and scrubbed everything. Took the boxes inside the rear SAM apart and scrubbed everything. That's how I found out that this car had gotten water in it at least once previously; there was some old oxidation. That's now completely gone.
So, this time, when I discovered that the blower motor went bye-bye, I did the same to every fuse in the two front SAM's, as well as that little box with 4 or 5 fuses and two relays next to the front passenger SAM. Also did every fuse in the passenger-side fuse box (right-hand side, here in the USA).
Blower motor still wouldn't come on. Then, I found this thread.
https://www.benzworld.org/forums/w220-s-class/1518325-how-do-i-get-my-c.html
Oh, was this a lifesaver. Did the testing in there, and sure enough, it's the blower motor. New Behr blower is on the way. Also am replacing the regulator/resistor with a new Behr OEM unit, since I'm in there anyway. Might as well do it all at once and get it all knocked out.
By the way, the dealerships, and FCPEuro, are both being given bad information about which part number is correct for the regulator/resistor. They're all saying that part #2208209210 is right for the W220 chassis. This is *not* correct; the correct part number is as follows.
2308210251 (old)
2308216451 (current, as of today)
Here's the evidence, from the one I pulled out from the '03 S600 TT, this evening. Thumbnails are clickable.
So, keep a sharp eye, folks.
41 - 58 of 58 Posts
