1999 ml320
hey guys going to replace hoses in wiper system this wknd cause of poor flow, i just want to know does the 99 ml320 have a checkvalve in it somewhere and do any of u know what it takes to take off the cowl? thnx bb
1999 ml320
cowl removal
43sqd that was perfect and right on time checked my email before i went out and it was there,i didnt have the puller so i just put the nut on there a few threads and squeezed it up with channel lox and it worked great, and the cowl removal instructions were just what i needed,cleaned check valve and replaced old hoses now all worx fine thnx so much for ur input and pdf`s they saved the day lol cause i really had no ideas on that cowl and didnt want to break anything but alls well thnx again.bb
· Outstanding Contributor
2002 ML320, 2003 A160, 2002 ML500, 2018 GLS350d
After I replaced my washer reservoir, the flow was poor due to plastic fragments (of the old washer pump nozzle) lodged in the check valve. I followed these instructions but was defeated at the "remove wiper arms" step.
It is possible to remove the check valve without removing the wiper arms. Raise the hood to the vertical service position so you have room to remove the rubber seal. Each of the 5 metal clips has 2 spurs on the front edge, so pull the rubber seal forward and down to unsnag it before pulling up. After undoing the plastic 10 mm nuts and removing the leftmost 2 clips, you can lift up the front edge of the grille just enough to get the check valve out.
