G
I have had my car in three times for a creaking noise that occurs when I go over bumps. It is most pronounced when I hit off set bumps or the kind that are similar to the tire drill football players run through. The dealer has been less than helpful and has blamed everthing but the car. I was wondering if anyone else has had this problem, and what possible solutions one might suggest. Any help is greatly appreciated. I can dupicate a portion of the noise if I push the woodgrain inward from the center of the dash.
G
Discussion Starter #2
it's probably cracked...try another dealer. they should replace the whole thing under warranty
G
Had same problem with 02 CLK55 Cab. Noise was from a broken A/C duct housing on drivers side dash. Dealer replaced housing now all's OK.
