Same thing happened to me one time. Brake fluid cans were all dented and boxes for other parts broken open. Amazing air filter survived.Just got a box from FCP today. Mahle fan clutch is Made in China. Lemfoerder motor mounts Made in China. Lemfoerder transmission mount Made in India. Sigh. I was also disappointed in FCP packaging. They literally threw my parts into a box without padding and shipped them. That included transmission and brake fluids which somehow did not leak.
You are right, they are steel. I should have gone and checked before typing. They broke so easily, I assumed aluminum!Those are steel thread forming bolts. If they are breaking just below the head they are stuck in water pump hole.
I have been sitting thinking about what I have or can get locally to get those bolts out.For that one stud that's sticking out, use something like this....
Others will need to be tapped and drilled in very carefully.
Using fine wire brush and sharp scribe try to remove as much corrosion at the base of the bolt. Right now corrosion seals thread entry and penetrant will not creep in. Kroil is choice of penetrant.
Thanks - I hope I get to that step soonIf M8 bolts came out with normal force reuse them. Order new M6. All those bolts are coated with Dacromet. It gives them bluish appearance that some folks mistake for blue thread locker.
Yellow gunk is residue from coolant dye. I fill seal groove with silicone grease to keep seal in place. You will have to maneuver new pump into oil cooler hose and behind temp sensor clip from bottom up. Need to make sure seal does not get dislodged in the process.
I'm just poking fun at BW in general. Been a trend I've noticed lately, threads with very technical issues are resolved even before the first page is done, whereas threads with basic ass stuff like misfires, changing tires, and yes, water pump, gets to multiple pages.Looks like you may win your bet.
We are now at #96Still, that's good news that you're finally coming to the end!
I admittedly have started a few long threads! Technical issues not always resolved. Living where I do, there is only one other DIY guy that I know who works on old MBs. And they are mostly 123 diesels (I also have one of those). These forums fill the gap.I'm just poking fun at BW in general. Been a trend I've noticed lately, threads with very technical issues are resolved even before the first page is done, whereas threads with basic ass stuff like misfires, changing tires, and yes, water pump, gets to multiple pages.
All good. Different styles.I admittedly have started a few long threads! Technical issues not always resolved. Living where I do, there is only one other DIY guy that I know who works on old MBs. And they are mostly 123 diesels (I also have one of those). These forums fill the gap.
This is a thread that went all over the map before I finally discovered the actual problem. It got to post #210.
This one only got to #77 . (apparatus case blower)
This one only got to #53, but may have to be re-visited
#98 and counting....I better go out and do some work.
