Wife said that yesterday, she had no start when she turned key. But then on second try it started. She went shopping and it started after each stop.
This morning, she went to go out and the car would not start. Starter dead. Turn key to start position - no click no nothing.
I know that no-start is not an uncommon problem on this forum, so did some of the threads.
I first checked battery and although it tested out Ok voltage wise, it was not so good on a load tester. It was 10 yrs old, so as a first step, I bought a new battery. So now we have about 12.56V and climate panel displays 11.6V. This of course with engine not running!
I tried jumpering the starter relay A-C. Still no starter. With key on, I do see a small spark when inserting the jumper. So some power getting there. Checked resistance D-B - both relays about 85 ohms
Next, I replaced the entire K-40 module with a new one that I happened to have as a spare. So there should now be a new starter relay as well as all new fuses. Still nothing. Checked all fuses, and they are good.
So, what to do next before I have car towed to dealer?
