2012 ML350, 2005 AMG E55, 1998 E320, 1993 300CE CV Wide Body Twin Turbo
Do you guys know if the stock mirrors on the 98 e320 US are prewired for the mirrors with the turn signal built in? or do I have to run the wires through the door?
Also
What about the folding mirrors with the turning signal, do I need to run any wires for that?
If any one has done either one please help me with the detailed instructions. I'm looking to buy a pair and can't make up my mind (folding or not).
1999 E320 Wagon
Running wire through the door is not that difficult. Take some time to examine the wiring and you'll see it is not that hard. E Klass posted something on this a while back when he did the upgrade.
Folding mirrors would require much more effort. Maybe even a control module swap.[xx(]
SLK320, MKV Jetta TDI, Mini Cooper S, Lincoln Mark LT
To add the folding option, you will need to add a switch to the dash. The connector just needs to be changed and 2 wires added for the blinkers. Tap in to the blinker wire in the wire trench under the door sills on each side. Takes a few hours to install them.
