While my wife was driving to work this morning the odometer switched from showing milege to showing all 9's. Trip Odometer and all other instruments are working correctly. Any suggestions? I was going to try to remove battery connections when I get home.
SLK320, MKV Jetta TDI, Mini Cooper S, Lincoln Mark LT
Sounds like your memory chip that holds your total miles just went. Try unplugging the instrument cluster.
Resolved
I pulled both fuses to the Instrument cluster for about 5 minutes. Working correctly ever since.
W203, W210 Moderator
E55 ///AMG
Good to hear that, you might wanna check that terminals for the fuses are not lose and clean & check the fuse too just for future problems..
