1998 CL500
I have spent hours at the dealership and online, what I am looking for are the 2 clips that hold the recirculation filter panel onto the firewall. when you undo the 2 screw type clips I assume the filter panel should pivot down.
does anyone have any idea,
what these clips look like
part number
anywhere else to look?
CL500 W140 '97 Coupe
I know what they look like because i have recently removed and cleaned the Pollen filter.....it appears they get broken regular because of their poor design/fitment.
One of mine is broken and the other hinge/clip is missing altogether!
Havn't a clue on part number but my advice would be to source a breakers yard and explain to them the item you require.
Good luck.
1998 140.070 CL500, 1966 406.121 U65
Do not know about any clips, but last time I looked, mine is
being held by 2 integral plastic hooks that extend upwards from the recirculation
panel. Yes, if not careful, they seems so break rather easily.
Go to this page;
http://www.auto-parts.spb.ru/cat/cats/m.mycat?Form
and look in the;
83 HEATING AND VENTILATION
then
045 HEATER CASE WITH BLOWER
and you'll find the part number for part 323;
A 140 830 09 13
which then is the complete panel, for a LHD car, which I think its what you'll need.
Edit, if yours RHD (in Australia?), its;
A 140 830 03 13
Heres another one, with the same mechanism of filter fastening as I have;
http://www.benzworld.org/forums/w140-s-class/1378151-under-dash-filter-replacement.html#post2892805
and this;
http://www.benzworld.org/forums/w140-s-class/1199390-interior-cabin-filter-removal.html#post1405735
And lastly, a full DIY with pictures;
http://www.peachparts.com/Wikka/W140BlowerMotor
br,
syljua
1998 CL500
PeachPartsWiki: Diagnosing the Blower Motor and Cabin Filter
[/QUOTE]
thanks Syljua, you certainly are a wealth of knowledge.
currently I have what is in #12 picture on the above link. it has the release screws.
Are you suggesting the other end clips are purchased as a unit with the recirc panel?
when I look on the firewall where the panel should hinge I find 2 square holes, like there should be some push in type clips.
I suppose what I really need is to find another CL500 and have a look but there aren't may around in perth, not many merc wreckers with this car either.
thanks
Not following you completely here. Do not know which image is #12, but the first
one with a image of the filter cage, explicitly mentions that the screws in the
pictures does not have to be loosened?
br,
syljua
1998 CL500
br,
syljua
apologies should be 13th from the top and not screws, release tabs.
