1 - 9 of 9 Posts
1994 S500 Coupe
My steering wheel won’t stay straight when going over anything besides completely flat roads. The smallest bump or uneven section of road will make the wheel turn and it’s very annoying. What could be causing this?
1994 S500 Coupe
Discussion Starter · #5 ·
a shop you've used before? i'm surprised no recommendation for front end work.
I had an accident and the rear right wheel and suspension had to be replaced so they didn’t want to do more work as it was already an expensive visit. The alignment shop isn’t the same as my mechanic i’m going to take it back to my mechanic soon to get the issue resolved i was just trying to see what it could be so i can prepare myself for the cost of the work.
E350 Sport
i saw the toe was way off on rr. what you're describing i'd think it was tie rod ends or control arm bushings. how was the tire wear before alignment?
yep they can be expensive. i had my triple black for 10 years, top needed replacing + top cylinders & i traded for the e350 sport.
now i'm driving one of a bazillion 4dr sedans.
i do miss the timeless look of the sl but the amenities with the 350 are sweet.
1 - 9 of 9 Posts
