1989 E190 2.6L , 169k
Going to the scrap yard tomorrow and need some help removing the rear bumper on a 97 e420? Also what bumpers would be compatible?
Tools needed etc?
Thank you in advance
to remove the bumper you have to pull out the trunk liner on each side there is one bolt on you have to remove then it slides off to the back.
As far as I know any w210 bumper will fit but the trim on the facelift bumpers is slightly different
Second that on the fit. You will need a 10mm socket for the corner and middle bolts, and 13mm deep socket for the 3 rear nuts. It's a 5 min job removing that bumper. Only thing to watch for is most will have an antenna in the rear bumper so you will need to pull that wire out of the car and then the bumper is all yours.
