When removing the pin, which secures the pads, it seems as though it cannot be fully removed unless the brake line is removed. There is only one pin on this model and aligns with the brake line. Is there a way to remove the pin without removing the brake line, making it necessary to bleed the lines?
Outstanding Contributor Always Remembered RI
Welcome to Benzworld
