3.2 + V12 W140
sorry 1996 not 97. hey. my mums c180 AUTO is a right sod this year. got only 64k on the clock and for the past fmonth it has been fien, BEFORE; it would cut out usually when you had the radio on and were at low speeds, usually coming to a stop. no warning, always started up again just very random engine stopping. took it to merc a few times and they said no faults at all they just reset something as you do after a head gasket job appaerntly. i have done the head gasket, then changed heads etc totally cos the cam decided to snap in half on the road test, then we have done a couple of little things to the gearbox as the vac pipe come off and the prop coupling was shot away. and replaced the battery. AND i redid some of the engine wiring loom as this car obviously still came with the crap wiring loom that falls apart after a few years. AGAIN, we have had merc and the aa etc and an auto electrics place look for a bloody fault and there is absolutely nothing to report.
NOW, after a month, it happened again today as my mum was going along without the radio on.
the only thing i will say is the car will not start after removing the battery cos i was sat there for DAYS trying to start the bloody car after changing the battery on a few occasions! it was having none of it. but out of the blue afetr a few days of struggling to start (and i even tried my new 700 amp v12's battery and got the same shitty response from the car) it was fine, and is still fine starting up. but again if i pulled out the battery it will really go bad again.
i dunno what the hell is going on. ive spent nearly a thousand pounds on this low milage poxy car and thats with me buying cheap and doing it myself! it just stops. for no reason. no warning light no noises no nothing. ecu doesnt even have a record. (oh and no i dont have a cruise control!)
any ideas?
'2017' S550
I recommend you do a basic troubleshoot.
1. Verify you have fuel flow to the engine.
2. Verify you have spark to the cylinders.
If both are functioning properly then check for airflow passage.
If this was an initial "intermittent" issue I'm thinking it is likely electrical and my first thought would be "coil packs" have gone bye-bye. Troubleshoot and eliminate first.
deucer
3.2 + V12 W140
hmm. well everything seems fine when i have a look and test things. trouble is is it only happens when my mum drives the car. i have driven the car for 8hr in the past 2 weeks i.e i drove to one place 2hrs away and back one week and the next. had no trouble - i tried thinking what my mum does differently to me and all the garages and people have tried do. and the only thing was was that my mum has the radio on full blast, so we thought a new battery would do it as it was not holding charge anyway and as she drives for 10 mins to and from work we thought that was just i dunno, overloading it. but its fine when i drive it. and its as if something on the car just has a fit for a second enough to stop the engine and then you restart it and it carries on as normal :/
do you think the wiring loom deeper into the engine knooks and crannies is shorting out somewhere..?
'2017' S550
Logic says something is shorting to ground intermittently. If you know fuel is a known issue and obviously you are getting fire to the cylinders then it appears to be a short somewhere. Coils do have a tendency to short internally, but usually when that occurs it's not long before they fail completely. I suggest you go back over each wire in the harness you tinkered with originally looking for loose or exposed wiring that may ground to metal.
· W221 & Audio Moderator
2015 S550
While there are many knowledgeable folks on this forum, and they may be able to answer your question, you might get results more specific to your car if you post the question in the W202 forum that covers the c180. This forum deals with the W220 S-Class.
