1 - 12 of 12 Posts
1996 E320 Inline 6
I have read other threads about the tumbler going out. This might be the case in my situation, but I am curious about why the car does not see that I have inserted the key. I have the door open, the key in, and no chime/alarm telling me to take the key. Is this normal when the tumbler goes out or is this another issue. Thanks for any help anyone can provide.
Brian
one note to add: I installed a aftermarket radio 2 days ago. Could this some how triggered some anti-theft feature that would lock the ignition down? Just trying to cover all bases. Thanks.
· Banned
1999 E300 TD
Brian:confused:
I believe the reason you don't hear and can't turn anything is that the ignition switch has not recognized the key. WHY---could be low voltage, could be a bad key, could be a bad ignition switch.
I would start with the easy part---the battery. Good luck
2005 W215 CL500
The battery in the key has nothing to do with starting the car. You can start the car with no battery. It will be either a broken coil in the key or it will be the EIS module which is faulty.
1996 E320 Inline 6
Discussion Starter · #4 · (Edited)
The car battery is fine. The car started/key turned just fine an hr before it locked.
I have a standard blade key with no battery. I checked with the prevoius owner, and they said this happened before. They told me they jiggled the key/steering wheel, and the key just turned over. So that is why I thought it could be the tumbler.
Dallas, Texas
Brian:confused:
This is normal. Key in switch does not close until you turn to position 1 first then back to position 0. Fix tumbler issue first.
'96 with V6? Typo or transplant?
1996 E320 Inline 6
Discussion Starter · #6 ·
Yes, typo..straight 6. I will have to fix. My local MB dealer will not sell me the parts without having the car there. Is there a way around this. I feel like I can replace the tumbler after reading the threads here.
1996 E320 Inline 6
Discussion Starter · #8 · (Edited)
Thanks for the clarification on the parts order. After reading other members posts about the tumbler, I assumed they were able to just order the parts. It looks like I will have to pay a nice tow bill just to order the parts. I offered to show my Title, and Drivers license with no luck.
Well, I evidently spoke to the wrong person at the dealership..they will sell me the part with the proper documents.
· Banned
1999 E300 TD
You are correct, if you do have batteries in the key and this gent does not, they are not for ignition handshake purposes.
The battery I was referring to was not the key battery but the conventional auto battery typically stowed in MB's under the rear seat.
That battery is the battery that supplies the voltage to the ignition switch coil.
Thank you for letting me clarify.
We do have double threads on the subject?
If you can turn the key a bit, I would suspect the problem is not the tumbler, but the switch assembly that is attached to the shaft. Find the thread about tumbler problems in the stickies and read, read, read.
The MB key blockade is not something average DIY can deal with. Take an estimate from the dealer.
1 - 12 of 12 Posts
