1996 e300d
I just fixed my leakey Injection pump's delivery valves and after putting things back together started the car. I now get a P0200 error code which is a open injector circuit problem. The car runs ok (and leaks are gone) but I dont have a clue as to where to start looking for the problem. Has anyone had the same problem? And if so what is the cure. THANKS in advance.
Banned
1999 E300 TD
The P0200 OBD code are cross referenced by the following MB codes
P1220 IFI Fuel quantity Actuator
P1223 Fuel Rack Sensor
P1611 Internal reference voltage
P1613 IFI Control Module, microcontroller/quantity calculation
P1617 IFI Control Module, EEPROM or defective coding
P1622 Shutoff valve
You will notice that all the faults are injector pump or IFI Control Module related.
There are very specific individual tests to determine which is the correct one.
You don't have the tools or test equipment to complete the tests to determine the/fix the fault.
I would first clear the fault and see if it returns.
If it does you will need someone with good MB diesel injector pump testing experience or you can be foolish and start changing the three components------the shut off valve, the injector pump or the IFI Module. Don't listen to that advice. See a good MB diesel indy and ask his advice.
Good luck
