1 - 17 of 17 Posts
1995 S600 1995 Towncar
can any let me know the part number for the transmission oil for a 1995 s600:thumbsup:
Hey buddy i checked tht part # it comes bk as gear oil is tht still correct?
1995 S 420, 2012 GLK 350 and 1997 Audi Cabrio; Previously 1982 280CE, 1974 450SL, 1974 911S Targa
You should still have the 722.3 four speed auto transmission. This uses a Dextron III transmission fluid; I use the Mobil 1 synthetic, but the Castrol Transmax for imports is a good non-synthetic alternative, both available at AutoZone or O'Reilly's.
For MB automatic transmission (not including MB automatic transmission 722.6) use:
Castrol Dexron-III/Mercon ATF F-30341
Castrol Transmax M-22257 / 22096
Chevron ATF Dexron III F-30108 / 30159
Citgo Multi-Purpose ATF D-21571
Exxon Superflo ATF Dexron-III F-30111
Havoline ATF Mercon/Dexron-III F-30321
Pennzoil, ATF D-21380
Pennzoil, ATF F-30110
Quaker State Dexron-III/Mercon F-30161
Sunoco ATF Dexron-III/Mercon F-30176
Texaco ATF Mercon/Dexron-III F-30321
Unocal Multi-Purpose ATF D-22413 / 22431
Valvoline ATF Type D
Sdhow thanks for that info but i want to use the original benz fluid i know this topic has come up alot but just looking for the part #
The factory uses Fuchs for normal factory fill; Mobil 1 synthetic on AMG applications. My local dealer actually uses the Castrol Transmax in 55 gal. drums in their service bays. You can go to the dealer's parts dept. and buy the MB branded fluid...but don't be shocked by the price. I was quoted $32 per liter for the non-synthetic fluid...and you'll need 9 liters with the torque converter drain.
W124 Moderator
The PN I posted came off the label of the quart bottles I have in my garage and is the fluid I run in my 98 S500. Another forum member, who is an ASE Master MB Tech 27 yrs, suggested it to be the current reverse compatible fluid.
Jayare
Jayare
1998s use the 722.6 FIVE speed auto transmission (has the W/S switch on the gear change gate), which is an adaptive or "learning" transmission. It DEFINATELY does NOT use the same fluid as the 722.3 transmission used in the 1995 and earlier cars. I have no idea who your ASE master tech is, but this is W140 service 101!
W124 Moderator
I beg to differ with you but it is no big deal to me. The fluid I use is reverse compatible according to MB.
Sorry that won't work for you.
Good Luck
Jayare
Banned
1993 400E
#1, 1996 was the 1st year for the 722.6 transmission.
#2, 236.12 & 236.14 spec fluids are BOTH compatible
back to 722.3 transmissions. Get your facts stright before
spreading mis-information on this forum.
98 S500
I'll tell you what - the new stuff (236.14 fluid) made my 722.6 upshift and downshift harsher. I put in Vavoline MaxLife ATF which is other than Shell, the closest thing that you'll get to 236.10 fluid and my shifting was smooth again
No its NOT in my head and no my fluid level was not off before the change. Also, I had previously installed a new conductor plate (speed sensor failure), pressure regulating spring and a full drain (torque converter included) with a new filter and the NEW MB BS fluid and my shifting was harsher than my old ORIGINAL fluid.
The new fluid being 100% backwards compatible is BS. Folks in the W210 forum (which is the AUTHORITY on the 722.6) seem to think the same. Even G-AMG knows that the new fluid is BS and it had an effect on his shifting...
Banned
1993 400E
Out of all the 722.6 transmission service's I've done, which is at least
100, I've never had one shift hard with the 236.14 fluid.
It's also in my 722.3 trans and shifting is flawless.
What I said was the fluid used in the 722.3 transmissions (Dextron III) is NOT the same as used in the 722.6 transmissions. That is FACT. Can you use the newer ATF 3353 fluid in the older 722.3 transmissions...yes...but WHY??? It's like OVER FIVE TIMES THE PRICE and provides no better service!!!
Get your facts straight, sir.
BTW...the MB parts catalog shows the new fluid number to be superceded to A001 989 68 03 10...if you insist on using the unnecessary 236.12 spec fluid in your 722.3 ('95 and before) transmission. Good luck!
You DIY internet experts have a right to your opinions.:rolleyes:
Spoken like someone who charges his customers $300 for a $75 transmission service. I'd take G-AMG's advice over yours any day! :p
Banned
1993 400E
On your first point, I don't charge customers anything.
As a delaer technician I get paid flate rate which for a
transmission service is 1.5 hrs or $45 at my rate.
As far as advice, don't worry. I won't offer any.
1 - 17 of 17 Posts
