Hello,
My AC started blowing hot air on my way to the store so I turned it off. After shopping I started the car then press a button on the CCU, the engine choke then shut off.
If I leave the CCU on and start the car, it hesitate at first then idle just fine. Another problem here is that the blower seems to have stopped working even with the defroster or fan selection on high. I can feel only a breeze coming out of the correct vents with the temperature wheel at hot/cold.
I need help with where to start on this problem. Could it be compressor clutch
or blower motor (regulator), etc?
Thank you,
Thank you,
