i need to find the intake pipe that reads 3.6 on it for a reasonable price and not $700 if someone could help me out i would appreciate it. I also needed some information on what i can do to add mods to my car any info will help thanks to all!!!!!!!!!!!!!
1998 C43 AMG
Can't help with intake tube...
As far as mods... This has been discussed, so you could ...
As far as mods... This has been discussed, so you could check some previous threads, but I will try to give you the jist of things..
Chip. $600-$900. Generally 10-20 hp gain.
Supercharge. Not sure on price. Several thousand.
Kleemann does it, and about 140 hp gain.
Cold Air Intake (K & N) - $250. 5-7 hp gain.
Eisenmann Exhuast - Not sure $, 10 hp gain?
That's about it.. These cars are already "modded" by AMG!
CLK55/G500/E55/ML55/etc.
Re: Can't help with intake tube...As far as mods... This has been discussed, so you could
I don't believe Kleemann supercharges the C36. However, Mosselman does sell a twin-turbo kit.
-s-
360TE AMG; 500E
If you have the "early" flat-style air-intake cross-pipe, you cannot use the "FAT" air-int...
If you have the "early" flat-style air-intake cross-pipe, you cannot use the "FAT" air-intake cross-pipe with "3.6" on it UNLESS you also change valve-covers (I have the "flat" style pipe).
Anyone know what happenned to a member called "RASCAL" from the SF Bay Area, who had the Mosselman twin-turbo kit installed, in I think a C36?
Re: If you have the
His car is parked outside the Import Tuna shop. It was t-boned.
Here's info:
http://www.callandra.com/forums/showthread.php?s=&threadid=1004
-s-
