Mercedes-Benz S320
Hello. When my car shifts down while slowing, then accellerate, their is a slight hesitation - like the car is in neutral for a split-second, then goes into gear. The trans shifts fine going up through the gears. If you come to a complete stop, then the trans shifts normal. It seems to be some sort of "kickdown" problem. The "Check Engine" light is on & the code reads "upshift delay valve" (on trans).
Any Ideas?......... Thanks!
Depends on the day!
when was your trans serviced last? I would start there and once that is done adjust the mod till she's shifting more appropriately.
The UDV is for when the car is cold..thus not of major concern.
Jonathan
Mercedes-Benz S320
Discussion Starter · #5 ·
Hello Guy's! Thanks for the responses. I had the trans serviced (fluid/filter) two months ago. I'll have the modulator replaced with the upshift delay valve & let you know how it worked out.
