Hello,
I have a '94 Mercedes 320e that just developed a new engine problem which I guess I would have to call an engine surge while at idle. It doesn't run properly at driving speeds either.
The engine had been running great with no misses and lots of power. However, it suddenly developed a problem where (when idling in park) where the revs constantly modulate between 5 and 15 krpm. When driving, the engine sputters and loses power if the gas pedal is pushed too quickly and past a certain point. If the pedal is pushed completely down while the sputtering occurs, it will continue to sputter for a couple of seconds and then take off with full power and run properly with even after the gas pedal is decreased.
I suspected (possibly) that the MAF might be the problem but it seems to idle the same with the MAF sensor disconnected. I guess that this could indicate either a completely bad MAF unit or a completely different problem.
The car has always had problems. I've addressed problems with the fuel pump relay and bad solder connections in the OVP. These problems have been corrected and the car had been running very well for several months.
Would anyone know where to start with this problem? My car doesn't have an obd2 and old error codes from previous problems are still loaded on the "code box". I plan on clearing those today and disconnecting the battery to reset my system for a fresh start.
I've been running for a week or so with the same gas in the tank with no problems. Still at the 1/2 full mark.
Thank you in advance for any help or suggestions. I appreciate your time and help.
Regards,
Tim
Regards,
Tim
