1 - 9 of 9 Posts
I have a 1994 E320 Wagon and it seems to be completely dead. I was getting the clicking sound and dash lights so I replaced the battery knowing that the battery was old and the symptoms pointed in that direction. It ran fine for a few days but now if I go to start it it's completely dead, no lights, no clicking sound, not a peep of anything. I am new to these cars so any help for a nooby would be appreciated!
500SE AMG, E350 4matic, GL 450
Single click or continuous clicking?
Regardless, sounds like your alternator. Continuous clicking is more likely starter.
To check your alternator: Charge up your battery. Check the voltage. Run car and recheck the voltage. I believe the voltage should go up a couple of volts.
'94 E220
its the voltage regulator, its located inside the alternator, search google for that.
Make sure you get a new VR made by Bosch, not chinese crap.
And by the way, you should ask in the W124 section not general, thus you will get more helpful replies.
1995 E320 Cabriolet x 2
Welcome to the correct forum. Advice you have been given so far is good. Follow it, then report back.
1988 300CE, 1988 260E
Please fill out your profile, it will help others know where you are at and possibly a member on this forum lives near you and could assist.
1 - 9 of 9 Posts
