No brake lights. Replaced brake light switch. I have power at switch. Not sure where juice goes from there. I have a donor wagon so I can try other modules or relays but need some ideas. I tried fueses all seem fine.
Discussion Starter #2
So I count figure it out with info on forum. Brought it to independant dealer. They replaced computer control module/light relay which fixed brake lights,reverse lights and plate marker. 375$ total.
Should have done a search and bulb out indicator/headlight relay would have popped up. We have talked about it so much here its been beat to death I am thinking. Pretty sure it is stickied in the forum. When it comes to electrical its usually is it a 93and up (wire insulation issue)? change aluminum fuses to copper ended and clean contacts and any light issue clean ground and replace relay under the screwed down cover behind the fuses. It is the longest one in there.
Good Luck.
