1993 SL600
Hello,
I've a 93 SL600, and she won't turn start. Starter seems to turn over for about 1/10 second, then the solenoid clicks. Battery is fully charged. I've got the Bosch trouble shoot guide - is it easy to replace the starter on the SL600?
Thanks!
Jimbo
1993 SL600
Yes, we're VERY lucky - as we won the SL600 in a raffle! $100 raffle ticket won a '93 with less than 5k miles when we picked it up.
But the task at hand -
Are the bolts readily accessible for a replacement?
Is there much other dis-assembly required to remove the starter?
Thanks!
Outstanding Contributor
2005 SL600, 2003 SL55, 1990 300SL
The only disassembly required to R&R the starter is the removal of plastic panels from under the car. You may also need to remove one of the chassis stiffening struts -- no big deal.
Hint: turn the steering all the way to the left.
