That sounds like the MAS box and that contains the fuel pump relay. 6 months ago a would have said that the MAS box is OK. For me, a quarter of a century with the same one. But I had a 'no start' and that was solved by changing the MAS.It’s points me to a box that looks more like a module.
Maybe but my more general advice with these (and probably any) cars is to clean electrical contacts whenever and wherever you can get at them. Buy a good quality contact cleaner (NOT ordinary WD40) and spray, plug, unplug several times then repeat, to make sure all pins and sockets are cleaned.would the pin having all that gunk
It is incorporated in the MAS module, which is located in the ECM box on passenger side.No, the car used to start and stay on for a while before it just fine, before it would unexpectedly cut off. After the ovp issue, it starts and dies right away. Correct me if I’m wrong, I’ve looked for fuel pump relay location here and it shows me that there is no relay for my car. It’s points me to a box that looks more like a module. Is this the correct part? And if not, where is the fuel pump relay located on a 93 300sl? Thank you again
Highly unliekly in my experience.I keep hearing about the crank sensor
