I’m not sure if I’m in the right place. I’ve looked everywhere on the internet and in your forum for similar cases to my car, and so far nothing like it. So I bough this 93 300sl not running. Looked really good and complete minus the ignition control module. I found a used module online and bought it. Connected the different sensors to it and the car turn on like clockwork. It idle a bit high but I figure that was normal since the car had not ran for a long time. The po mentioned it hadn’t ran for about a year. So I let it idle for a bit, after a few minutes I put it in drive and that’s when I noticed the car would not engage into gears. It drove super slow and as I tried to accelerate harder it would kind of just want to turn off. To the point it just turns off randomly. I’ve replaced dristributor cap, rotor, cables and some rubber hoses. Still have the same symptoms and I just don’t know where to start looking. So again, the car will start fine, idle ok, and after a few minutes will just die out randomly or if I try to put it in gear and drive off it has no power and shuts off as well. Any help or suggestions would be much appreciated. Thank you in advance.
