I have only had the car 2 weeks and haven't bought a service manual,yet. I turn on the key, one notch and the SRS light comes on. the owners manual says the Batt. light & glow plug light should come on. One more notch and most of the indicators come on after a while the glow plug light comes one but goes off when you turn it to start . Any help would be apreciated.
BenzWorld W126 & W201 Host
1988 420SE, 2002 C180 Kompressor, 200 ML320
If the glowplug light is working in the reverse order, i.e. it is off when you turn the ignition on and comes on as you start the engine then it is probably a faulty glow plug.
It is normally No. 5 or 6, but if you replace the set, it should cure the problem.
