Hi,
I need your help. I need to replace the crankshaft position sensor on my 92 MB 500 SEL, as the RPM gauge is working intermittently. I am not sure how to access the sensor.
84 500 SEL ...94 S420..... 95 S500.... 96 S500 95 S600
It is located in the back of the engine, on the left side ( drivers) of the transmission bell housing. Its mounted in an aluminum housing and held in by one bolt. Remove the bolt twist and pull upward and it should come out. Once its out of its housing follow the wire to the ignition control module located on the drivers side inner wheel well under hood also, pretty easy to remove and install the new..Good luck!!
